Forum Home Forum Home > Arcade Technical and Restoration > Arcade Artwork
  New Posts New Posts RSS Feed - Artwork Resources - Vector & Scanned Art
 Post Reply Post Reply Page  <12
_Ste_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Ste_ Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2014 at 5:51pm
arcade artwork . org has been removed from the web
Cocktail wanted Please inbox me :)
RetromanIE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RetromanIE Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2014 at 7:21pm
Only temporarily while I argue out a few issues with my hosting provider :0)
They've taken down all my hosted sites, but should be resolved in the next week or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RetromanIE Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2014 at 10:14pm
arcadeartwork.org is back online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Ste_ Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2014 at 5:59pm
arcade art library offline, error 404
south central emulation, deactivated
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2014 at 6:31pm
Removed the south central one, that disappeared for a bit, then came back but seems to be gone for good now.
I'm still hoping Arcade Art Library returns, I do have most of the files from there so will look to host them somewhere if it doesn't come back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RetromanIE Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2014 at 7:21pm
I've added a good chunk(25GB) of very high res stuff to the arcadeartwork.org site(and Google Drive) over the last couple of weeks.
If you're looking for something from the closed/shut down sites I might have it.
Kewydee View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kewydee Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2014 at 11:16am
For Muddymusic - I cannot send you a PM so i'll put my message here.
Hi, I would like a quote for the following items please, there is no rush, I am still trying to get as much info as I can and then hopefully build my very own cab
Zaccaria Star Splash Bezel
Zaccaria Mr Do! Marquee to fit a UR2 cabinet (same as Paul Swann's Cabinet)
Zaccaria Star Splash 2 button Control Panel
And the tricky bit..
A vinyl of the Star Splash side art
I have searched and will keep looking for scans of the side art, seems there was a Norwegian guy who was doing it on the Dragon's Lair Forum but has had delays so it's not done quite yet.
I've seen the amazing job you've done for artwork, you are the guy to ask. I also see you are very busy with many people contacting you. Please let me know if you get the time.
Thanks for looking, hopefully you can use your wizard skills to make my dream cab a reality.
PM me if you can - I couldn't get PM's to work, is it me or are they switched off for now?
Cheers.
frothmeister View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote frothmeister Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2014 at 11:21am
Cheers.
You need to make 10 posts on the forum before you are able to send/read PM's.
I'm sure you'll be there in no time, just post some more about Zacc cabs. I love them too!Smile
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kewydee Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2014 at 11:44am
Cheers - I am a forum noob
I didn't know much about Zaccaria unil I saw that associated leasure flyer for the Mr Do cab. That is almost exactly the same as I played back in the day. I have been reading as much as I can find, still have much to learn.
Thanks for the tip, good on ya
capcomguru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote capcomguru Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2015 at 8:18pm
Does anybody have any good japanese art scan resources? I know they're out there... Japanese re-sellers have an endless supply of copied art...
