Forum Home Forum Home > General Arcade Chat > M.A.M.E
  New Posts New Posts RSS Feed - HOW TO CONVERT A JAMMA CAB TO MAME- IN 100 STEPS!
 Post Reply Post Reply Page  <12
Kilgore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kilgore Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2013 at 7:50am
Awesome read thank you!! Just what I need to kick start my project!!
venom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2013 at 11:21pm
Your welcome kilgore, enjoy the "fun" !
Added a few links to the shops in to.
Edited by venom - 18 January 2013 at 11:31pm
Owner of Lordsvale Cabinet and Thunderbirds pachislo slot machine.
Type X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Type X Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 8:29pm
Thanks for the guide picked up a few tips on bits I was stuck on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2013 at 10:57pm
Lost my stickie Cry so bumped for chubsta !
Edited by venom - 31 March 2013 at 11:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2013 at 10:35pm
Bumped for nervosa lost my sticky
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 9:16pm
Admin can you sticky me again please ?
showstopper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote showstopper Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2013 at 9:57am
Great job. My mate has a Wrestlefest arcade which i believe is JAMMA and not JAMMA+. He wants to mame this cabinet. I think i have everything in my head for what i need to do:
PC - winxp or win7 - need some advice here - i think 7
nvidia 7600gt
jpac
The only thing i need to figure out is wrestlefest is 3 buttons and we want to turn the CP into a 6 button per player cabinet. So do i wire the extra buttons to the jpac? Or do we need a kick harness? If it is the kick harness where do you plug it into as i thought the kick harness plugs in the game PCB?
Post Options Post Options   Thanks (1) Thanks(1)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2013 at 9:15pm
I'd use xp, ther were some issues with 7 but they may have been fixed by now.
Good luck drilling the cp out !
ps.
see this in full but to answer your question:
What controls does the JAMMA connector support?
The JAMMA standard supports 2 players with 3 buttons per player. There is an unofficial addition to this, some cabinets wire a fourth button. Plus coin, start etc.
Thats not many buttons, what about any others?
Game boards which need more buttons have an auxiliary button connector which can vary in type. This is not part of the JAMMA standard. The J-PAC caters for these extra buttons by having screw terminal inputs for these extra inputs.Inputs supported directly through the JAMMA connector are:Player 1 and 2 joysticks, Player 1 and 2 buttons 1,2,3,4. Coin 1, Coin 2, Start1, Start2.
Inputs supported by the screw terminals are:
Player 1 and 2 buttons 4,5,6,7,8.
Note that button 4 can be connected via either method as some JAMMA harnesses route this button through the connector.
If you have a 4 player cabinet you can use an I-PAC2 board as well as a J-PAC and plug the I-PAC into the pass-through connector of the J-PAC. You will need to re-program the I-PAC board for correct player 3 and 4 keycodes.
andrew79wiggins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrew79wiggins Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2014 at 12:41pm
Brilliant guide thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 10:32am
No problems,
But my biggest tip is save time and money , buy one that is already done :)
Also decide what you want first.
I am at one point to get another cab. Probably keep the neo geo in one player  and put the mame into a two player 19" cab instead.
Best thinkg about a smaller 14" screen cab is its dead easy to replace the monitor at little cost as Amiga monitors are easy to get hold off, unlike arcade monitors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2014 at 5:56pm
This cab may be up for sale shortly
gavinb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gavinb Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2014 at 5:58pm
your small one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2014 at 7:49am
Mental note on dimensions of cab.
50cm wide X 69CM depth by 158cm tall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2014 at 8:46am
No longer for sale going to now have two cabs !
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2014 at 9:41am
Admins can you re-sticky me please  under Sharky ooer  mrs !
BigBadWolf View Drop Down
Forum Patrol
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadWolf Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2014 at 9:49am
There you go dude..!
***Peace, rest, no stress and some sleep wanted!
Trump for President
dotacon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dotacon Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2015 at 11:32pm
Very useful!
BertramWooster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BertramWooster Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2015 at 10:46pm
Thanks for this, it's going to come in very useful for me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2015 at 11:43pm
No worries hope it helps you out.
If jammaplus stays I'll tidy it up a bit...
Post Options Post Options   Thanks (0) Thanks(0)   Quote venom Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2015 at 12:53am
Any chance an admin can re-sticky me please ?
