Forum Home Forum Home > General Arcade Chat > Players Guides/Walkthroughs and Tips
  New Posts New Posts RSS Feed - Gameplay Audio Commentary - R Type (Arcade) - 1CC
 Post Reply Post Reply
Ex_Mosquito View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ex_Mosquito Quote  Post ReplyReply Direct Link To This Post Topic: Gameplay Audio Commentary - R Type (Arcade) - 1CC
    Posted: 10 August 2013 at 2:08pm
Heya, this is my first try at gameplay audio commentary. I've wanted to do this for a while. Sometimes just putting up replay videos can be a little soulless, so I thought I'd try talking over one to make it a little more personal and to give people some insite to my gameplay approach. I was a bit nervous at first but I loosened up half way through. It's harder than I thought! ;)
Edited by Ex_Mosquito - 10 August 2013 at 2:35pm
My Arcade 1-Credit Replays
http://www.youtube.com/user/exmosquito
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ex_Mosquito Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2013 at 5:28pm
Gonna try and tackle the 2nd loop now I think. It isn't as intimidating as I first thought. Got to knock of Ben.Shinobi's western dominance of R-Type! ;)
Fuzzy View Drop Down
Novice grunt herder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuzzy Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 9:16pm
I am watching and learning! Thumbs Up
Great vid, thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ex_Mosquito Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 10:10pm
Cheers Fuzzy :) I am going for a 2 loop 2million+ pts now. I wanna try and get in the world top 5 scoreboard on the 360 Xbox live version. Unsurprisingly the top 5 players on the scoreboard are all from Japan and are all 2-loop 1-Credit clears :/ gonna be a challenge, getting there slowly though.
I dug this out the other day when I decided to go for the 2-loop clear. It's a 'green-dot enemy' spawn map I made of level 4 when I made my replay last year. I needed it again because I'd forgotten where they all came from! :/ I find having a quick formation sketch of a particularly tricky section alot easier for me to get a mental picture rather than just a random cluster of enemies. It helps me loads, my memory is a bloody sieve these days..
@7:40
Edited by Ex_Mosquito - 19 September 2013 at 10:03am
Nicko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nicko Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2015 at 10:45pm
The vid wouldn't work for me. Wanted to check if you're aware of the 7th level boss 'cheat' for racking up huge scores. Basically place your ship in the small indent of the boss structure (fits the nose perfectly) with attachment behind. Just keep firing until just before the boss times out, then kill yourself. Rinse and repeat till your last life. Bear in mind though starting mid 7th level is the trickiest place to start during 1st loop, so make sure you have that mastered first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ex_Mosquito Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2015 at 11:24am
Heya. Yeah I'm aware if the milking technique on the level 7 boss and suiciding until your last life. The restart point after a death on the level 7 boss is brutal isn't it. I wasn't going for a highscore run on this replay. If I was I was I would've milked the level 2 boss instead of going for a quick kill. And I would've killed all the piston enemies on level 6 instead of dodging them.
I may revisit this in the future, the 2nd loop is sooo tricky though :/
drewmunro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drewmunro Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2016 at 11:02am
Great video thanks
