OutRun Mini Restoration |
Page <12345 7> |
dj_yt
Joined: 24 February 2010 Location: Surrey, UK. Status: Offline Points: 485 |
Posted: 21 March 2015 at 8:30pm |
The base plates are back from metal treatment (at last, these were away over a month!)
I had these clear zinc plated. I liked the idea of having brighter base plates than the standard UK model where they seem to be painted black. The base plates were badly rusted before I sent them off, and there are still signs of pitting. Thankfully, almost all of these are on the underside of the machine so won't be seen. Also, zinc plating is a more cost effective option! I also fitted the replacement grey matting I purchased. Again, I opted for grey to match the promotional shot of the mini cabinet (and bring things closer to the deluxe cabinet), rather than the black that it was originally in. Remember the corroded bolts I hacksawed from the base of the machine, that originally held the base board in place? I replaced the captive nuts with new zinc plated ones. I also had a brake pedal chrome plated, to match the accelerator pedal I got from David Plus, my Dad reports that every single capacitor has now been replaced on the monitor.... it will need to be tested. |
dj_yt
Posted: 21 March 2015 at 8:40pm |
Stood the cab back up... yes getting there.
dj_yt
Posted: 29 March 2015 at 7:19pm |
Stuck the vinyl side-art on. This side-art is similar to the American mini cabs, which as far as I can tell had genuine vinyl stickers. The UK cabs were stencilled.
One side went on perfectly. The other side I annoyingly had a few issues around the 'A' of the SEGA logo. Here's a close-up. These aren't air bubbles as such as you can squeeze them out / flatten the vinyl and they vanish. They are areas where the vinyl hasn't stuck correctly and has popped up. I suspect this happened because we repositioned this corner within a few minutes of first sticking and in doing so lost the full adhesive of the glue. Grr. My plan of action is to clamp the art into place with some perspex. I've read this can work, but I'm somewhat sceptical. Does anyone have any advice here? I could heat this section of vinyl again and restick. What sort of glue is best? |
joe34
circa 1985 Joined: 13 July 2012 Location: cornwall Status: Online Points: 3648
Posted: 29 March 2015 at 7:23pm |
nice progress
hey what caps are you needing perhaps list them here?
dj_yt
Thanks(1)
Posted: 29 March 2015 at 7:34pm |
Monitor has had every single capacitor replaced.
Some issues with horizontal width, and loss of the Blue and Green colours intermittently to figure out. If you can help, please post in this thread. Edited by dj_yt - 29 March 2015 at 7:35pm |
muddymusic
Official Porchy fan club member Joined: 08 June 2010 Location: Cornwall Status: Offline Points: 14365 |
Thanks(1)
Posted: 29 March 2015 at 7:39pm |
If it keeps popping off use some spray contact adhesive then clamp it flat and leave it to cure.
Side art looks really nice on vinyl, applying full side art is never an easy job. |
dj_yt
Posted: 29 March 2015 at 8:23pm |
Thanks. Any specific brand you'd recommend? To be honest, I'm still not entirely sure why one side had these issues and the other side was absolutely perfect. I didn't change my technique massively. Could be the adhesive, could be we somehow stretched the vinyl when applying, could be the fact we peeled and reapplied. I find most steps of this restoration involve me cursing my handwork (or lack of it!)
dj_yt
Posted: 29 March 2015 at 8:27pm |
I'll certainly post a full list at some point. This is the PE 07 chassis revision, which I don't think is covered by any of the existing cap-kits. EDIT: Done, see below!
Edited by dj_yt - 04 April 2015 at 9:02pm |
dj_yt
Posted: 04 April 2015 at 9:01pm |
Monitor capacitor details posted here.
On the artwork side I waited around 5 days, removed the clamps and the situation has improved: I then used a hairdryer to remove some of the remaining kinks. The results aren't OCD perfect, but they are close. Let's hope it stays this way! |
hitbyambulance
Joined: 04 April 2015 Location: Seattle, WA Status: Offline Points: 2 |
Posted: 04 April 2015 at 9:52pm |
i have your Reassembler blog on RSS, and i registered here at the forum to track your progress on the restoration. looks promising! i'm guessing the monitor will be the trickiest part to resolve, at this point.
mrrygar
Joined: 30 August 2014 Location: uk Status: Offline Points: 66 |
Posted: 05 April 2015 at 7:09pm |
really coming together now :D side art looks great, where did you get it from if you dont mind me asking cant wait to see your next update |
dj_yt
Posted: 05 April 2015 at 7:26pm |
The sideart was made and also printed by a Florida based chap called Rudy Benvin, who I contacted through an online forum. It wasn't cheap to import from the US, but beggars can't be choosers! I can put you in touch if necessary.
He was also willing to sell the digital files, but I figured it was safer to have him handle the whole process for me. One interesting thing to note on the art, is that the UK stencilled art actually extends underneath the protector plates at the bottom of the cabinet. I think the original vinyl US artwork did not include this lower section. Most images of US machines I can find on the net also show the artwork not extending as close to the edges of the cabinet. The promotional Sega shots of the cabinet show the cabinet without the side base plates, and without the control panel artwork. You'll notice the replacement artwork also does not include the lower triangle which is partially obscured by the base plates. Next stop: restoring the accelerator and brake assembly. But more on that soon...
Edited by dj_yt - 05 April 2015 at 7:44pm |
muddymusic
Posted: 05 April 2015 at 10:51pm |
Sega flyers always seem to have differences from production models. That pic also lacks the dashboard artwork that the cabs originally went out with.
dj_yt
Posted: 07 April 2015 at 10:26pm |
Time to restore the pedal assembly! It was pretty grimy.... grease, dust and corrosion everywhere!
I dismantled the assembly and initially washed the components down with a high-powered hose in the garden! I scrubbed everything until it positively hurt. Baby-wipes, IPA, wire wool etc. I resprayed various components. Even the screws! I managed to salvage almost everything. The only new part was the accelerator hinge and pin from David, as the old one was worn. One thing I got wrong when initially reassembling, was I put the central spindle in the wrong way round. This wasn't immediately obvious, it was so covered in gunk when I disassembled I didn't take note of this, so take care! The spindle was greased. The other accessible parts I'll grease before they go into the cabinet. Overall I'm pretty pleased how well this turned out!
cmonkey
Joined: 15 October 2012 Location: Leeds, UK Status: Offline Points: 800 |
Posted: 07 April 2015 at 10:32pm |
Looks almost as good as new! Excellent work!
muddymusic
Posted: 07 April 2015 at 10:33pm |
Nice work, that looks great.
Bods
Ninja Warrior Joined: 25 September 2004 Location: Leicestershire Status: Offline Points: 10081
Posted: 07 April 2015 at 10:39pm |
I've done a whole cab with cans and it came out awesome, would recommend it with plasticote spray cans |
WANTED! Buggy Boy Junior Rear Seat. Continental Circus Cockpit Lower Rear Marquee. Electrocoin Rampage Marquee
dj_yt
Posted: 08 April 2015 at 6:38am |
Right I'm getting you round to do the next one then!
Eddhorse
Joined: 18 March 2014 Location: Dublin Status: Offline Points: 342 |
Posted: 08 April 2015 at 11:32am |
Looks great, that pedal assembly is amazing compared to the original.
AdamsArcade
Joined: 29 July 2013 Location: Staffordshire Status: Offline Points: 189 |
Posted: 10 April 2015 at 4:54pm |
Wow! Seriously impressed with the amount of work you've put into making this look like new. Kudos. Great thread, plenty of reference material for when (not if
) I eventually get my hands on one!!
Wanted:
Outrun Cabaret |
Page <12345 7> |
