Forum Home Forum Home > Arcade Technical and Restoration > Repair Logs
  New Posts New Posts RSS Feed - Taito Bubble Bobble Repair Log
 Post Reply Post Reply Page  <12
karatechamp999 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2015 at 11:30pm
thanks for responding! I've already piggybacked a new 157 over all the 157's and no change
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2015 at 11:36pm
which ttl's are the counter's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2015 at 11:27pm
Well, I have piggybacked every ls157/ls283/ls04/ls163/ls169 and no change arrrghh
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2015 at 2:13am
had a thought :-) I had this same problem before and after I resoldered a clearly broken pin-11 on LS374 at IC97, this should narrow it down, shouldn't it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2015 at 2:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2015 at 10:34pm
Well, I purchased another BB bootleg that has some issues aswell, anyone interested in taking over this project? someone that can also do the REDUX upgrade - can keep one of the boards as partial payment - thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote ben76 Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2015 at 11:00pm
Have you read the aussie arcade fix log?
http://wiki.aussiearcade.com.au/index.php/PCB_Repair_Logs_Bubble_Bobble
Hope the link works as I am using my phone atm. Third time is the charm lol it is for an original pcb but most boots are pretty much identical
Edited by ben76 - 30 March 2015 at 11:02pm
I Porchy
Post Options Post Options   Thanks (0) Thanks(0)   Quote karatechamp999 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2015 at 12:47am
lol yea twas hoping to just sub in the other video board from the second bootleg but when I got it I noticed they are slightly different and I'm unsure you can just plug-n-play do different video boards fromm to different bootlegs - wish I had pinouts for the 60pin connector the joins the cpu to the video pcb but alas can't find them especially for two different bootlegs :-(
