HOW TO CONVERT A JAMMA CAB TO MAME- IN 100 STEPS! |
Page 12> |
venom
Joined: 13 November 2009 Location: Bristol Status: Offline Points: 2565 |
Topic: HOW TO CONVERT A JAMMA CAB TO MAME- IN 100 STEPS!Posted: 09 April 2012 at 11:24pm |
Update 20/12/2015 Dont bother reading this post and wasting hours of your life building on Windows XP. Just read this and buy one ready made for you. Then buy from 2human instead well worth the money and saves shit loads of hassle ! Updated July 2014 http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=22768&PID=452234#452234 I decided to role my sleeves up.. Thanks for all the support. I hope this is a useful guide to others.
COSTS Next time I will just buy a mame cabinet will be cheaper and less painful
Required: Jamma switcher £50 from the US http://www.jammaboards.com/ J-PAC £55 (UK) If you have any mates that can run through their business you can save 20% ! Speakers/amp 6.99 delivered From Maplins bought they keep altering product code Gameex £20 lifetime license (I dont mind funding decent work) but there are a number of free Front ends http://www.gameex.com Hidden Costs: New Jamma power supply as switcher is fussy about voltage £22 (UK) Ebay July 2014 ***If you are only going to run a PC and your monitor is powered from the mains, you don't actually need a Jamma power supply. I have proven this as unplugged mine ! The j-pac gets its power from the PC. You can then set the PC bios to recovery mode. This means you can cleanly log out of XP as normal within your front end, and power off at the plug. Then when you switch Plug socket on again it will go into power recovery and boot PC up cleanly, no need to press the PC's power button. I.e I have my mame cab set up now so I never have he to go into cab for the pc or the keyboard or the power switch. Jamma Extension harness 8.99 Members business... THE CURRENT CABINET This is a small cabinet with a 1 slot ne geo mobo on it running witha 14 inch arcade/amiga monitor. I have the original Toie still which was set vertically before. Luckily the amiga monitors run at same frequency as an aracde monitor and are a lot cheaper/easier to get. PC Hardware Bought a 3.0 AMD XPC Shuttle, 120GB ide harddrive 2 gb ram £40, Thought would be small enought to fit in cabinet. But shuttles look bigger in the flesh than in the photos ! Removed Network card as wanted to keep build to a minimum and keep of the network. What a mistake that was in hindsight should have put on the network so could use terminal services to make changes to it when it had been attached to cabinet. PC SOFTWARE Installed all from CD or a distributable, as not web connected. O/S Windows XP sp2, there is something about issues with xpsp3 and gameex Free in a packet of cereals ! Other Needed Stuff Direct X_june2010_redist (direct X last version for XP) http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8109
dotnet35 (Actually .net 3.5sp1 with all the previous versions as well) http://www.microsoft.com/download/en/details.aspx?id=22
Windowsinstaller-kb893803-v2-x86 http://www.microsoft.com/download/en/details.aspx?id=25
InstantSheller. Did not use this in the end I just put Gameex in the startup. Winipac. Did not use this in the end as managed to set two of the arcade buttons using ,ame to send an exit command to mame. 15K monitor stuff. Gave up with this is the end treated myself to an arcade VGA card Quickres http://www.ultimarc.com/download.html
Soft15khz (Did not get this working in the end) I did it but got various issues *open quickres, a galaga icon appears on bottom right of your taskbar. *click the galaga icon- select "640 x 480 32bit"- your desktop is now the correct resolution for the arcade monitor. *open soft-15khz. *select ONLY the 15khz option to install. *shut down your PC. At low resolution just fell into a big heap... Exception at EIP=01014435 (drawd3d_window_init(win_window_info*)+0x06a5): ACCESS VIOLATION While attempting to read memory at 00000080 ----------------------------------------------------- EAX=00000000 EBX=00000001 ECX=7C91056D EDX=00150000 ESI=00000001 EDI=002FDB58 EBP=0022E828 ESP=0022E1C0 ----------------------------------------------------- Stack crawl: 0022E828: 01014435 (drawd3d_window_init(win_window_info*)+0x06a5) 0022E8D8: 00FF34B5 (complete_create(win_window_info*)+0x02f5) 0022E9B8: 00FF3AC5 (winwindow_video_window_create(running_machine&, int, _win_ monitor_info*, _win_window_config const*)+0x0525) 0022EAF8: 00FF01B5 (winvideo_init(running_machine&)+0x0a75) 0022EC48: 00FEBF5C (windows_osd_interface::init(running_machine&)+0x02dc) 0022ED68: 016454B8 (running_machine::start()+0x0298) 0022EE18: 01646434 (running_machine::run(bool)+0x02c4) 0022F988: 0162EFCC (mame_execute(emu_options&, osd_interface&)+0x022c) 0022FBA8: 0191BC42 (cli_frontend::execute(int, char**)+0x0f02) 0022FEB8: 00FED5BF (utf8_main(int, char**)+0x01df) 0022FEF8: 01BBD52E (wmain+0x006e) 0022FFC0: 00401422 (__tmainCRTStartup+0x0292) 0022FFF0: 7C816D4F (RegisterWaitForInputIdle+0x0049) In the end I used this instead of soft 15K CRT_emudriver_6.5_1.2_xp32_multisynch (used this instead of soft 15k) MAME Have learnt that you should use the version of mame that is for the roms you have downloaded. I have a full mame set from feb 2012 about 40 gb in roms and 20 gb in extras. This version requires a mame 0145 version. After testing mamegui, mameuifx, arcademame and cabmame, I settled with MAMEUIFX Depending on which version of mame you have you should set the mame.ini or the gui to make sure it is taking advantage of the hardware in relation to aracde monitor. Here is the link for full details http://www.ultimarc.com/avgainst.html
mame.ini For mame verions that use mame.ini.... if this file does not exist- make one! (start>run>(type) "MAME -CREATECONFIG" >now go to mame folder and open the .ini with notepad, edit as follows.. # VIDEO OPTIONS # video ddraw numscreens 1 window 0 maximize 1 keepaspect 1 prescale 1 effect none pause_brightness 0.65 waitvsync 0 syncrefresh 0 # # DIRECTDRAW-SPECIFIC OPTIONS # hwstretch 0 # # FULL SCREEN OPTIONS # triplebuffer 0 switchres 1 In the end I used MAMEUIFX and I set the the default settings in that to Display Tab: VideoMode: DirectDraw Stretch Using Hardware = OFF (if this is greyed out you have notswitched Windows to 16 or 32-bit colour mode) Screen Tab: Screennumber = 0 Screen = \\.\DISPLAY1 Resolution, Size = Auto (or select from drop-down list in game as required) Switch Resolutions to fit = ON I then put gameex shortcut in my startup. I Also configured gameex to run Mameuifx EXITING MAME WITHOUT HAVING A KEYBOARD IN THE CABINET. One you get it all working when you are playing mame you may want to quit a game like you normally would be pressing escape. If you have not got a keyboard installed the J-pac already has a code built in. If you hold player 1 and press player 2 button it will do what used to be done by pressing escape. If like me you do not have a two player cabinet, you can set it to use other buttons instead. This is the easiest way you must first load mame and start playing a game. Brill when in a game click tab Then selected "Input (general)" Then "User Interface" Then Scrolled to the "UI Cancel" I pressed return then quickly pressed keyboard keys "1" and "left shift" Now I can simply hold down fire button 4 and then press player 1 start button and it acts like escape used to i.e exits the game and brings me back to my Front end. For some bizzare reason it wont work by holding down player 1 then hitting button 4. It has to be button 4 held down and then press player 1. This is strange as the other J-pac commands work fine by holding player 1 down then moving the joystick. Any way its working and doing what I need it to do thanks all.... Full post here FRONT END I chose GAMEEX, dont do this use something easier ! Install GAMEEX first, then copy the roms and mame into the default paths specified in gameex. In gameex tell it to use arcadeVGA settings. I also set it not to filter the games list. Otherwise it does not display different versions or bootlegs of the games. In the end I actually told gameex not to use an arcadevga card, I just configured al my settings in mameuifx instead, saved any conflicts of knowing what was overiding ahat If you are using a arcadevga card you do not need to read the below on soft15K. I have left it in for if people are using say a ati 9200 card and the software instead. In the shuttle I had the following card but with gameex it would not load properly ![]() So I installed the catalyst software as previously stated that helps with ati cards. http://mame.groovy.org/WindowsATIDrivers/ July 2014 update as above link down Use this site for drivers Catalyst 6.5: ATI Radeon 7000, 7200, 7500, 8500, 9000, 9100,
9200, 9250, 9500, 9550, 9600, 9700,
9800, X300, X550, X600, X700, X800,
X850, X1300, X1600, X1800, X1900,
X1950, ArcadeVGA 9200/9250, etc.Handy hit build the pc in he comfort of your lounge on the TV and get it all working as you like before moving it to the arcade machine. OTHER HARDWARE INSTALL As I wanted to run both a neo geo and a mame pc in the same cabinet I needed to buy a two way jamma switcher and find a place to install it Inside the front seemed a good idea.... Before After First attempt to get PC working in the cabinet. Moved my jamma harness to the board then installed a J-pac and bloody thing did not light up at all and I could not switch boards. Forum members advise that these boards need slightly more than 5 volts from the jamma harness. New power supply was ordered where you could alter the 5v upto 6 volts. Strangely I turned it just to 5 volts to begin with and that worked fine. I could easily switch between my neo geo and the mame pc. J-pac picture: I has a spare Jamma exntension lead which I thought I would move to the other swicthers port and discovered it had pin 9 cut out ofit instead of pin 7 ![]() In the end i bought a jamma extender cable from retropit which is ran by one of the members in this forum. This gives me time to think about where to put the PC I removed the coin drawers at bottom of cab and fits very snuggly. But I am worried its too snug and may overheat. I am considering cutting a hole in the piece of wood BEHIND the Coin drawers, sacralidge or not ? I.e you will be able to see the front of it instead of it being on the side. I think the cabinet will be fine ![]() Dont worry about the wiring that will be tidied up later, once I decide where PC is going and I have the new power supply. To be continued as at present works fine on the LCD TV but does not work in the cabinet ! Resolution issue with gameex or windows ? Another member is helping with this and also saw shark factor comments .. *unplug the lcd monitor. *plug the vga cable you took from the lcd, into the j-pac*. *plug the usb cable into the j-pac and your PC *set ONLY the 15khz jumper on the j-pac. *use the DVi out on your gfx card if it has one- soft-15khz will choose the DVi if your card has one and will not work through VGA! if you have no DVi out, no worry!, if you have DVi out- use it! -still no worry! Getting Arcade machine Games working to right resolultion. First of all set the actual graphics card to 640X480 using Quikres otherwise some of the front ends. Gameex in my case bomb out with no menus. When I firs tried my serrings Gameex would work but only certain games would play properly e.g JJ SQUAWKS Worked fine But Altered Beast would look like this ..... This only happened on Arcade Monitor on LCD played fine. I tried lots of different things and all versions of mame I tried mame , Mame32 and MameUI did the same. But then ....... MAMEUIFX worked fine and ran altered beast apart from when launched via GAMEEX. This proved it was a configuration issue, rather than a monitor or catalyst issue. After some help from members on other posts This is what I did to resolve it..... Deleted Mame.ini Then went into DOS and typed "MAME -CREATECONFIG" Then edited any setting in the mame.ini to how it is explained on http://www.ultimarc.com/avgainst.html
# # VIDEO OPTIONS # video ddraw numscreens 1 window 0 maximize 1 keepaspect 1 prescale 1 effect none pause_brightness 0.65 waitvsync 0 syncrefresh 0 # # DIRECTDRAW-SPECIFIC OPTIONS # hwstretch 0 # # FULL SCREEN OPTIONS # triplebuffer 0 switchres 1 I ran mame outside of Gameex and ran fine for altered beast and rtype. Robocop the screen presented was really small though ? I started gameex and told it to launch Mame and then just a black screen ? ![]() I went into the Gameex and found settings for the Arcade VGA Card and instead of saying Yes I have one, I said NO in case there was a conflict. Gameex ran fine and loaded the games fine, yipee. I then decided to try and fix robocop resolution by running AVRES http://www.ultimarc.com/avgainst.html
However after doing that Robocop was still only in a small part of the screen and Rtype would no longer work monitor would not handle the resolution. I will delete the associated files and put it back to how it was, I can live without robocop being full screen ! Then I ordered an arcadevga card and did this instead and it fixed robocop and al the other games, ! I.e they displayed as they should do on an arcade monitor. SOUND Because I want to keep my neo geo speaker in the cabinet and keep my jamma sound seperate I am going to take the sound directly out of the PC. This involves buy a usb powered Speaker, stripping the amp out of it, a small bit of soldering. You then connect the + and - of one of the original speakers to a special speaker + and - in on the J/pac itself. Basically unpackage the amp cut and isolate the speakers wire that was in the amp/speaker speaker (the red and white wire). Then find the line in and solder right and left line in together. Then wire the big long speaker wire into the J.pac + and - My bad soldering Finished I am suprised it still worked ... The following posts are useful, the top one shows how bad an amateurs soldering can be ! I bought these for 6.99 delivered http://www.maplin.co.uk/sweex-2.0-usb-powered-speaker-set-624478
Although you can build a project box to host the amp. I just drilled a small hole in my cabinet shelf and screwed it down within the speaker housing itself. Bit lazy but did the job " CAB FINISHED YIPEEE ![]() To get rid of the keyboard in the cabinet and save lots of scrolling for gamess create a favourites list in your front end. Here's mine.... Pacman Donkey kong 1941 counter attack Galaga Mortal combat Bubble bobble Street fighter 3rd strike Killer instinct 1.5d Altered beast Alien vs predator Shinobi Green Beret Golden axe Robocop Caddiliacs and dinosaurs Double dragon 2 Last blade Pang Outrun. Phoenix New Zealand Story Galaga 88 Gradius/Nemesis Salamander 720 Ghosts and Goblins Gryzor Rolling Thunder R-Types Willow Hyper Sports Tron Space Harrier Afterburner Paperboy Choplifter Gauntlet 1943 Ghosts and Goblins Marble Madness Star Force (the number of 10ps this ate in the SU could bail Greece and Spain out) Afterburner Paperboy Kung Fu Master R-Type Terminator 2 Commando Hyper Sport Edited by venom - 20 December 2015 at 11:52pm |
Owner of Lordsvale Cabinet and Thunderbirds pachislo slot machine.
stevearcade
6-Button Basher Joined: 18 June 2010 Location: Eastbourne, UK Status: Offline Points: 5563 |
Posted: 10 April 2012 at 9:18am |
What a mission. Mind you, I find anything to do with my cab ends up being a lot more convoluted than I first expect it to be. If I do anything to cab (even tiny jobs like tightening a screw) I go into it expecting it to be an absolute mission!If it's of any help, I have much the same setup to you in this video of my cab. It's a bit old now as I've changed the computer and sold the 1-Slot, but the principle is the same: Good luck with the rest of it man. ![]() |
Put that in your PCB test rig and smoke it!
venom
Posted: 10 April 2012 at 4:15pm |
Cheers Steve, I'll keep going and maybe try mala like you suggest see the other post !
Out of interest why did you sell the 1 slot. I am assuminhg that the emulation will be a lot worse than the original mobo ?
At moment I have a 1 slot wiith a multicart and originals of shocktroopers (very good quality labelled original !) , andro dunos and puzzbobble and puzzle de pon.
stevearcade
Posted: 10 April 2012 at 5:27pm |
The "original" puzzle bobble was actually a boot
. Emulation ain't bad at all on the PC for puzzle bobble actually. In truth, I've not come across that many games where the quality of emulation concerns me. I sold the one slot as I needed some cash and I bought puzzle bobble in the first place for the Mrs except she never bloody played on it. So figured I'd sell it and use the money for me .
venom
Posted: 13 April 2012 at 6:42am |
Got some more things to try today.
Does anyone see a big issue cutting a big bit of the wood out behind the coin doors ? The Bottom picture. It does not "appear" to strengthen the cabinet. I assume it is there to stop the drawers being pushed into back of the cabinet. I am a bit worried the shuttle may overheat in the small space it is in. I dont want to cut the outside of the cabinet to install fans. Some heat should also go up where the holes are in the wood were the coins used to drop from. If I cut a hole out behind the draws i also have opportunity to put the pc in with the dvd drive facing me and will be easy to get in and out of needed. It wont destroy cabinet as you wont see it when the bottom door is locked up. Edited by venom - 13 April 2012 at 6:44am |
BigBadWolf
Forum Patrol Joined: 23 March 2006 Location: Stirlingshire Status: Offline Points: 6162
Posted: 13 April 2012 at 11:56am |
i would de-case (or lid off) the shuttle and put it whereever you desire. then, remove the shuttle case fan(s) and hot glue them where ever you want, one blowing onto the cpu/mobo and another above extracting air out the space and into the cabinet (those holes you were talking about above where the coins fall through, fix a fan there for extraction..)
my mame pc is on a board, mounted vertically in the base of the cab.. i have not experienced any over heat issues.. ![]() ![]() ![]() with wooden cabs, i usually just decase the pc and fit it anywhere there is space for it, if the space is small, putting in a couple of case fans does the trick.
***Peace, rest, no stress and some sleep wanted! Trump for President |
ZedEx48K
Game Over
Joined: 25 January 2012 Location: Under a bridge Status: Offline Points: 1067 |
Posted: 13 April 2012 at 1:36pm |
The problem with older shuttles that I know of is they use heatpipes and variable fans on the back not on the cpu, they get bloody hot at times too so I would deff increase the cooling solution, not sure if the lid off is the best bet with the cooling design in them. The wood panel behind it looks to be held with some dowels, mebbe remove the entire panel by cutting them in half, you can reverse that at a later date then.
PS Sharkfactor, get that graphics card supported ;) |
venom
Posted: 13 April 2012 at 3:21pm |
Blimey that is some lot of wires !
Cheers for the ideas chaps I now have mame working for altered beast :) |
BigBadWolf
Posted: 13 April 2012 at 4:16pm |
ZedEx48K
Game Over
Posted: 13 April 2012 at 4:22pm |
If you mount the mobo next to the mdf you can bend and drill the end of the metal like how the top works, or a simple metal arm screwed to the mdf above the card that you screw/bolt to the top of the card, or get a shit old pc case and cut out the panel complete with the backplate to hold it in.
I may have built more than a few MAME cabs in my time ![]() |
singy1uk
Joined: 02 December 2011 Location: Blackburn Status: Offline Points: 1291 |
Posted: 13 April 2012 at 6:36pm |
Use a piece of metal coat hanger and bend one end into a loop to screw it to the wood board and then hook the other end under the mounting plate on the card.simple but works.
Mark.
venom
Posted: 30 April 2012 at 1:08am |
Updated first post to try and make this more like a user guide following some recent activity.
venom
Posted: 06 May 2012 at 12:03am |
Robopcop screen size issue is now fixed.
Even with the arcadevga card and avres Robocop was running at a small resolution like a photo within the screen. Thanks to Stryker I have changed my version of mame and altered settings within the gui defaults rather than ini setting I mention in my first post. I will tidy the first post up later. All is working lovely now and this is my recommendation Downloaded Mameuifx and I got gameex to run it and still got the same issue robocop in a small screen. SoI ran Mameuifx manually and still the same issue. So I then went into the settings within mameuifx and noticed it was using direct 3d. So I set the following VideoMode: DirectDraw Stretch Using Hardware = OFF (if this is greyed out you have notswitched Windows to 16 or 32-bit colour mode) Screen Tab: Screennumber = 0 Screen = \\.\DISPLAY1 Resolution, Size = Auto (or select from drop-down list in game as required) Switch Resolutions to fit = ON ROBOPCOP then worked fine Then I exited mameuifx. Ran Gameex and all working ok. SO I guess it proves mameuifx is not using the mame.ini as I had set it directdraw when I was messing around with mame.exe. I have had a weird issue with screen on machine being unreadable when left on windows xp for a ong time, kind of divides into 4 and unreadble. Also did this when spending ages updating the game list. It has not done this in an actual game yet. Its not the vertical synch issue its something else. I am hoping it does not start happening when I play games for a long time ! As soon as I flick back to my neo geo mobo that screen is ok. When I flick back to pc its still corrupted. This may also be an issue with the eary arcadevga card. I have removed the 31K jumper from the jamma switcher to see if that makes a difference. Thanks for everyones help I will tidy the main post up later. I am currently adding these to my favourites and hit no issues so far .... Pacman Donkey kong 1941 counter attack Galaga Mortal combat Bubble bobble Street fighter 3rd strike Killer instinct 1.5d Altered beast Alien vs predator Shinobi Green Beret Golden axe Robocop Caddiliacs and dinosaurs Double dragon 2 Last blade Pang Outrun. Phoenix New Zealand Story Galaga 88 Gradius/Nemesis Salamander 720 Ghosts and Goblins Gryzor Rolling Thunder R-Types Willow Hyper Sports Tron Space Harrier Afterburner Paperboy Choplifter Gauntlet 1943 Ghosts and Goblins Marble Madness Star Force (the number of 10ps this ate in the SU could bail Greece and Spain out) Afterburner Paperboy Kung Fu Master R-Type Terminator 2 Commando Hyper Sport |
venom
Posted: 06 May 2012 at 7:37am |
Final Finished picture !!!
venom
Posted: 09 June 2012 at 6:58am |
Bumped fro webbo and hitesh
venom
Posted: 05 July 2012 at 6:07am |
Bump for droo
venom
Posted: 19 August 2012 at 11:22pm |
Just re-reading my post, that is when my shocktroopers was working
venom
Posted: 28 August 2012 at 11:16pm |
Bumped for Sicoe
venom
Posted: 28 August 2012 at 11:19pm |
Come on make me a sticky admins
venom
Posted: 24 December 2012 at 8:41pm |
Updated: Although originally i had borders on the neo geo mobo, I have now resolved this by firstly altering the vertical pot on the arcade monitor to stretch it. I then had a nightmare trying to get mame to fit the screen properly. Games like pacaman lost the bottom of the screen. This was fixed by some great ideas by members on this thread
Anyway heres what I did. Firstly downloaded latest groovymame for windows and stuck the exe in the same folder I had mameui in Then.... http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=44750&title=arcade-vga-mame-and-neo-geo-vertical-size-fixed Deleted c:\emulators\mame32\mame.ini AGAIN Renamed my c:\emulators\mame32\ini FOLDER to INIOLD Renamed groovymame.exe as too long to type its full name ! Went to DOS typed C:\emulators\mame32\groovymame.exe -CC Then installed catalyst driver 6.5 from here http://www.mame.3feetunder.com/windows-ati-crt-emudriver/ Easier to read than spanish website ! Interestingly they recommend Some cards listed above have known problems with low dot clocks. For best results, a Radeon 9250 (AGP), Radeon X300-X600 (PCIe), or Radeon HD 4xxx (PCIe) card is recommended. Rebooted and Windows XP screen was fine but then screen picture unreadable as wrong frequency\settings. Whoops forgot to set soft15K ! Restarted XP pressed F8 Loaded windows in VGA NOT Safe mode Installed Soft 15K again and selected the graphics card. Thought is was a 7000 and accepted it fine. Rebooted Started Groovymame.exe and voila pacman fixed and looking pretty decent (at last can see bottom of maze and ghosts) ! Reconfigured Gameex to use Groovymame.exe instead of mame.exe. Rebooted again and voila all works near perfect, even robocop (never got that working before) and final fight looks brill spot on for the screen. Yes a slight hit on rtypre but it's hardly noticeable if you dont look for it, its a few lines top and bottom. Perhaps I can make a custom ini for that (If I can be bothered). Thanks everyone forgot how good mame was in a cabinet ! |
Page 12> |
